Post a new Topic with REST - 403 Forbidden
api
(Aarskin) #1
Continuing the discussion from How can we create post/topic in Discourse using API:
I’m POST-ing the following URl from Advanced REST client and getting the same error.
http://[my discourse ip]/posts.json?title=“Created from the advanced REST client”&category=“2”&raw=“A whole bunch of text about a topic”&api_key="[key from admin tab]"&api_username="[admin username]"
I built up the URL by referencing this, [this] (How can we create post/topic in Discourse using API), and this (but I’m looking for a language agnostic solution). I’m hoping I missed something obvious.
Why am I getting a forbidden response as an admin user with an api key?
(Pointing me to How to reverse engineer the discourse api will not help me, I’ve read it twice)
(Aarskin) #2
It was something simple: I had quotation marks in my query string. Removing them solved my problem. I.e. I modified the query string in the original post to look like this:
http://[my discourse ip]/posts.json?title=Created from the advanced REST client&category=2&raw=A whole bunch of text about a topic&api_key=[key from admin tab]&api_username=[admin username]
… and got my 200 OK response! :smiley:
Still not clear why I was getting a permission error based on that mistake though.
How can I identify a topic created using the API?
(Jeff Atwood) #3
@techapj can you add to your list better error information when quotes are used around query string data in calling the API?
