Post creation race condition
(Vikhyat Korrapati) #1
On our forum we have “chat” threads which see a fairly rapid rate of post creation. We recently switched to running Unicorn and Rails 4, and have also started seeing these errors around the same time:
 ActiveRecord::RecordNotUnique: ERROR: duplicate key value violates unique constraint "index_posts_on_topic_id_and_post_number"
DETAIL: Key (topic_id, post_number)=(2068, 9104) already exists.
It looks like this happens when two Unicorn processes try to create a post at the same time, but end up setting the same post number as a result. This is the relevant part of the stack trace from New Relic.
(Sam Saffron) #2
Do you mind posting that screenshot again, you uncovered another bug with out image cleaning job
(Vikhyat Korrapati) #3
http://hastebin.com/ruwenojoqi
(Vikhyat Korrapati) #4
Would computing the post_number inside the same SQL query help?
(Sam Saffron) #5
I think we can fix this race condition, how frequently does this happen?
(Vikhyat Korrapati) #6
NewRelic reports that error as having occurred 38 times in the last 24 hours. It is not a show-stopper or anything since it will normally go through on retrying, but it is definitely a minor annoyance.
(Sam Saffron) #7
Belated … but I put a fix in place for this now:
https://github.com/discourse/discourse/commit/9147af1d62c30dbc1f22ef4c576cd499cc50b100
Note, I chose to go with a redis mutex cause we need to ensure our post_numbers are sequential and this help avoid being left with holes on failures.
(Sam Saffron) #8
