Post not deleted after 24 hours?
(Sander Datema) #1
Just noticed a post in this thread that should have been removed 6 days ago.
And if this post was flagged, shouldn’t that be noticeable?
(Filip) #2
strange, I deleted it and I don’t think it was flagged…
(Jeff Atwood) #3
That post was flagged as spam so this is correct.
(Sander Datema) #4
Your edit of my topic title doesn’t really help: that was not my question, I also said it was not clear that the mentioned post was flagged.
(Jeff Atwood) #5
Well, we did clarify that flags are private in the UI, so you wouldn’t expect to be able to see the flag.
I guess it is an open question if we should delete the post after the flag is handled though @zogstrip. Perhaps the deletion check should try again every day or so until the flag has a disposition.
At any rate not a bug.
(Sander Datema) #6
People only see that if they click the flag icon. I’d suggest changing the copy in the post itself to:
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged. Flags are private and only visible to staff)
(Jeff Atwood) #7
Eh, that’s a lot of words to put on every self-delete. It’s pretty easy to figure out, and you figured it out as alluded to in the OP:
Occam’s Razor and all that :wink:
