Post pagination broken due to faulty css
#1
Hi there,
I just upgraded the forum to v1.9.0.beta13 +149 and at the same time installed the discourse-adplugin V 1.0.2
I am not running any ads yet and it seems my pagination is broken with posts not auto-loading the following pages.
Once you get to the bottom of the page it just sticks, doesn’t load anything further.
Tested across different browsers.
An example can be seen at
Can anyone shed some light as to the possible problem here.
Thanks, appreciate your time.
(Simon Cossar) #3
When I remove this css rule from your site
html, body {height: 100%;}
everything seems to work correctly. I think that’s been added through a site customization.
#4
Thanks @Simon_Cossar right you are :slight_smile:
Appreciate you taking your time to have a look.
