Posted Internal Link Not Loading Dynamically
(Vikas Dangi) #1
My problem is that when clicking posted internal links in my forum, they are reloading the full browser.
(Vikas Dangi) #2
Able to find the real problem behind it as mentioned in this post
@sam @codinghorror But still don’t know how to fix it.
(Jeff Atwood) #3
Do your links also lack protocol as in the previous topic?
(Vikas Dangi) #4
Yes, when I check the source code the href link have no protocol (http).
Exactly same as mentioned below in this post -
(Jeff Atwood) #5
Sounds like there is a problem with your configuration.
(Vikas Dangi) #6
I have installed the software by following the steps given in github discourse/INSTALL-cloud.md at master · discourse/discourse · GitHub
Did not do anything extra. My host is digital ocean.
(Vikas Dangi) #7
Another thing I found which may be causing the problem -
All the posted internal link in my forum ends with ‘?source_topic_id=62’ which may be causing the problem.
The internal links in this forum or in other discourse forums did not ends with this code. So I guess its the actual problem I am facing.
(Vikas Dangi) #8
Still finding the ways to fix it but can’t. Please can anybody solve my problem?
I have posted my internal links like this “http://domain.com/t/slug/123/1” but when I check the source code it producing links like this href="//domain.com/t/slug/123/1?source_topic_id=ID"
And the result is the link is not opening dynamically and refreshing the browser.
