Posting in a summarised topic breaks the progress bar
(Rikki Tooley) #1
Noticed this just now…
  1. Summarise a topic
  2. Reply to a post near the top
  3. Click on the post-jumper to get to my post (I had forgotten I was in filter mode)
Also, is there a name for this widget? Post-jumper sounds like an avant-garde clothing genre.
(Dave McClure) #2
I’ve been calling it the progress bar, but from now on I’m calling it the post-jumper.
(Jens Maier) #3
What? No, It’s got to be the Postcount-Creeper.
Just look at its adorable green color! :slight_smile:
(Sam Saffron) #4
I cant get it to break the scroll bar but it does behave quite odd in that your reply goes in the hidden section when replying to a post in the top.
repro
(Jeff Atwood) #5
@eviltrout this is an edge case but not showing your new post after posting in a summarized topic is kinda super bad. We should fix that next week.
(Robin Ward) #6
It wasn’t as bad as I thought. If you post near the bottom the post was showing up. It was only when viewing a page of summarized posts at the top and replying there. When jumping down, it wasn’t cancelling the summary.
(Jeff Atwood) #7
