Preformatted text formatting collision between HTML and Markdown
(Sam Saffron) #1
Preformatted text is bust under this condition (markdown issue):
echo '<pre>', print_r($polls) ,'</pre>
Works correctly in dingus .
cc @eviltrout
(Jens Maier) #2
It’s a problem with ordering: the Discourse code dialect fires before the markdown code dialect. This reorders the block dialects so that the Gruber code handler is always called first. Long-term, handler ordering should probably be more customizeable, but for now this works and also solves Gruber-style code blocks that contain matching [quote] pairs.
https://github.com/discourse/discourse/pull/2778
(Sam Saffron) #3
Thanks heaps :hamster:
(Sam Saffron) #4
