Prevent Badge IDs of less than 100?
(cpradio) #1
Continuing the discussion from Unable to edit type or delete badges created programatically:
Is this already being done and it wasn’t initially? Or is there room for improvement here to prevent user created badges from having an ID under 100?
(Sam Saffron) #2
This is already the case, no changes needed. Only way to get less than 100 is hardcode directly using the object model
(Michael Congiusta) #3
I’ve since fixed the problem, but when I created the badges initially I used the following code for iterating over a hash
badgesHash.each do |bName, bDesc|
  unless badge = Badge.find_by(name: bName)
    badge = Badge.create!(name: bName,
                         description: bDesc[0],
                         enabled: bDesc[1],
                         badge_type_id: bDesc[2])
No ID was hardcoded, so I’m not sure if I missed something.
Either way, probably pretty niche as I’m pretty certain badges created in the admin CP have their IDs set to over 100.
(James Milligan) #4
@sam - I’ve just started with a fresh Discourse install (still non-Docker, hopefully for not much longer). Creating a new badge in the standard way gives it an ID of 19, and it appears as though I can’t delete it. Is this related to your statement above, or something else? I’m pretty sure I could delete badges in a previous version.
(Sam Saffron) #5
What version are you on, I just tested here on meta and the constraint is in place.
In particular see:
This issue could be postgres version related … I dunno.
(James Milligan) #6
Just updated from the repo, still appears to be the same.
Clicking “new” and filling out the details as below, I still see the ‘Delete’ link. Once hitting ‘Save’, that goes.
Icon: "fa-user"
Badge Type: "Bronze"
Group: “Membership” (custom badge group)
Description: NULL
Badge Query: NULL
Allow badge to be used as title: 1
Can be granted multiple times: 0
Show badge on public badges page: 1
Show post granting badge on badge page: 0
Enable badge: 1
(Minor note - perhaps that second from last one should match the label above - badge page vs badges page)
I can’t edit the badge type either (i.e. bronze/silver/gold) nor the SQL.
This is on PGSQL 9.1.13, Ubuntu 13.10, brand new installation as of last night, updated a few minutes ago.
Just tried another badge in the “Other” group, type = silver, added a description, same checkboxes. Same behaviour in that I can’t edit some fields, and I can’t delete it.
(Sam Saffron) #7
anything in logs?
what is in the database?
(James Milligan) #8
CSV output of DB (left a ‘normal’ badge in there for comparison)
"20","IT & Forum Administrator","  ","2","1","2014-07-31 20:33:03.474936","2014-07-31 20:33:03.474936","t","f","fa-terminal","t","f","  ","t","f","8","  ","f"
"17","Reader","  ","3","0","2014-07-31 19:23:45.911073","2014-08-01 07:05:21.889238","f","f","fa-certificate","t","f","t","f","1","  ","f"
"22","Associate Member","  ","3","0","2014-08-01 07:12:55.393697","2014-08-01 07:12:55.393697","t","f","fa-user","t","f","  ","t","f","7","  ","f"
"23","Test Badge","Test badge","2","0","2014-08-01 07:17:41.448009","2014-08-01 07:17:41.448009","t","f","fa-certificate","t","f","  ","t","f","5","  ","f"
Log entry:
Started POST "/admin/badges" for 81.159.222.56 at 2014-08-01 08:12:55 +0100
Processing by Admin::BadgesController#create as */*
  Parameters: {"allow_title"=>"true", "multiple_grant"=>"false", "listable"=>"true", "auto_revoke"=>"false", "enabled"=>"true", "show_posts"=>"false", "target_posts"=>"false", "name"=>"Associate Member", "icon"=>"fa-user", "badge_grouping_id"=>"7", "badge_type_id"=>"3"}
Completed 200 OK in 190ms (Views: 0.3ms | ActiveRecord: 136.5ms)
Started POST "/admin/badges" for 81.159.222.56 at 2014-08-01 08:17:41 +0100
  Parameters: {"allow_title"=>"true", "multiple_grant"=>"false", "listable"=>"true", "auto_revoke"=>"false", "enabled"=>"true", "show_posts"=>"false", "target_posts"=>"false", "name"=>"Test Badge", "description"=>"Test badge", "badge_grouping_id"=>"5", "badge_type_id"=>"2"}
Completed 200 OK in 77ms (Views: 0.3ms | ActiveRecord: 59.8ms)
(Sam Saffron) #9
have a look at the the sequence on the table, does it start at 100 ?
(James Milligan) #10
Not totally familiar with PGSQL, is this what you’re after?
badges_id_seq
Current: 24
Min: 1
Max: 9223372036854775807
(Sam Saffron) #11
Yes, which raises the question, why did this migration run or work discourse/20140504174212_increment_reserved_trust_level_badge_ids.rb at master · discourse/discourse · GitHub
:wink: so hard supporting our non-docker installs
(James Milligan) #12
:blush: I certainly appreciate any help at all as I know it’s not officially supported.
I’d find it odd if something like this acts differently between this and a Docker install though?
(Sam Saffron) #13
Pg 9.1 vs 9.3 in docker setups
(James Milligan) #14
Ah… that’s probably a likely candidate then.
(James Milligan) #15
Thanks @sam - your commit earlier fixed the issue and has bumped the badges up as needed, they’re now editable.
https://github.com/discourse/discourse/commit/0b01310c843ae5eb002ef715a6d2160a1d30574c
(Sam Saffron) #16
