Preview-digest error
(Hosein Naseri) #1
I have just installed discourse and am testing it. in email section, when i click on preview-digest tab, it says:
server fault when trying to load admin/email/preview-digest.json
500 Internal Server Error
what is wrong?
(Sam Saffron) #2
@neil worth a look
Is there anything in /logs ?
(Hosein Naseri) #3
I think it produces the following error:
ArgumentError (comparison of String with ActiveSupport::TimeWithZone failed) /var/www/discourse/app/controllers/list_controller.rb:354:in>’`
(Neil Lalonde) #4
Hmm that doesn’t look related because it doesn’t use the list_controller… It should be the admin/email_controller.rb. Are there any errors for that?
(Hosein Naseri) #5
No I don’t see any error reported for email_controller.rb
(Neil Lalonde) #6
Ok, I don’t know how to reproduce it… Based on your first post, I tried a fresh install, went to Admin > Email > Preview Digest, and it worked. Anything else different about your test install?
(Hosein Naseri) #7
I’ve installed discourse alongside VestaCP if that makes any difference. And also the language of my discourse is Persian.
Does it require anything? maybe I didn’t configure something.
(Neil Lalonde) #8
I guess I’ll have to watch for it somewhere I can reproduce it and see an error.
(Hosein Naseri) #9
Is it a serious problem? I mean Can I ignore it for now? I want to lunch my forum.
(Hosein Naseri) #10
I can confirm that its a language issue. when I change the language to English, its ok. However when I change it to Persian (فارسی) it gives the same error.
(Jeff Atwood) #11
Then it’s a translation error, not a bug…
(Neil Lalonde) #12
Aha, I did find a problem in that case and made a fix. There are probably other languages affected.
(Hosein Naseri) #13
thanks. How should I update it?
(Neil Lalonde) #14
We’re planning to release a new version today, so the fix will be included in that update.
(Pad Pors) #15
sorry to bring this up! currently the preview digest is shown without error, but when I want to send a test email I got 500 Internal Server Error.
the forum is Persian (rtl).
the error log which may be related to this:
ArgumentError (comparison of String with ActiveSupport::TimeWithZone failed) /var/www/discourse/app/controllers/list_controller.rb:395:in `>'
(Hosein Naseri) #16
check this out:
