Problem running `./launcher rebuild app` : no output and nothing appears to happen
(Chris Croome) #1
I have upgraded one discourse server without a problem, following these steps but on a second one, after a git pull, when I run ./launcher rebuild app nothing happens, there is no terminal output.
I have tried docker stop app and then ./launcher rebuild app and still no output and also ./launcher start app doesn’t appear to start anything and also has no output.
The only difference with the server that upgraded without a problem is that this site has a Nginx reverse proxy with HTTP Authentication, could this be causing a problem? I have read through the launcher script and can’t see why it might.
Does anyone have any suggestions for what I could try next? Thanks.
(Jay Pfaffman) #2
That’s very strange. Maybe reboot.
(Chris Croome) #3
“Maybe reboot”, sorry but that sounds like a solution for a Windows machine… :frowning:
There must be some other things I can try before a last resort like that?
docker info reports that there are 9 running containers.
Does anyone have any other suggestions regarding how to debug this?
(Chris Croome) #4
There is a new version of docker-ce out so I upgraded that and then everything started working as expected, I still don’t know why I was having problems, but all seems to be good now :slight_smile:
