Problem when i install plugins
(DjCyry) #1
When i want to install a plugin , i get this error :
    FAILED
RuntimeError: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;} failed with return #<Process::Status: pid 1541 exit 2>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params "awk -F\\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print \"Authorized SSH keys for this container:\"; } NF>=2 {print $NF;}"
e7574f8884717c7d5455a1265b9883d
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
(Sam Saffron) #2
Need more logs please
(DjCyry) #3
@sam , doesnt show more info , only this :
FAILED
RuntimeError: awk -F# ‘{print $1;}’ ~/.ssh/authorized_keys | awk 'BEGIN { print “Authorized SSH keys for this container:”; } NF>=2 {print $NF;} failed with return #<Process::Status: pid 1598 exit 2>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn’
exec failed with the params "awk -F\# ‘{print $1;}’ ~/.ssh/authorized_keys | awk 'BEGIN { print “Authorized SSH keys for this container:”; } NF>=2 {print $NF;}"
ea5720343c2443f428e734c9867413ae95d3fe13079dc43147fe56726be40708
root@vps324:/var/discourse#
ssh : http://www.tupics.net/image/hUh
(Sam Saffron) #4
its in the screenshot, just unterminated string, just nuke your custom commands from app.yml you don’t need them
(DjCyry) #5
Nuke custom commands ? what do you mean @sam ?
i have use this tutorial for install plugins :
Access your server (use Putty on Windows)
Type cd /var/discourse
Type nano containers/app.yml
4.) Arrow down until you see this:
techAPJ:
hooks: after_code: - exec: cd: $home/plugins cmd: - mkdir -p plugins - git clone GitHub - discourse/docker_manager: plugin for use with discourse docker image
5.) Paste “- git clone GitHub - discourse/discourse-spoiler-alert: A plugin for discourse to hide spoilers behind the spoiler-alert jQuery plugin” beneath that so that all together it looks like this:
techAPJ:
hooks:
after_code:
6.) control + O (to save app.yml), hit enter
8.) control + X (to exit app.yml), then hit enter
9.) git pull (this updates stuff)
10.) ./launcher rebuild app (restarts Discourse and includes the plugin)
(DjCyry) #6
I have try to install only the “solved” plugin and i get the same error :
FAILED
RuntimeError: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;} failed with return #<Process::Status: pid 1592 exit 2>
c171a61b79468be78da05f8a09eaeb025e93e9e18f6fa00ccf70f6dc0fafd2a2
(DjCyry) #7
Anyone can help me ? thanks :stuck_out_tongue:
(DjCyry) #8
(Zack Piper) #9
Could you give us your app.yml with passwords ommited, thanks.
(DjCyry) #10
Sure , here you have , and thanks a lot :slight_smile:
app.yml (4.0 KB)
(Zack Piper) #11
Ran a diff on the file you gave me and the file from https://raw.githubusercontent.com/discourse/discourse_docker/master/samples/standalone.yml (default file)
You need to add a single quote: ' to the end of the line where it says “awk” :smiley:
(DjCyry) #12
OMG …ok , thanks , i will try again now to reinstall plugins .
(Zack Piper) #13
Haha, you’re welcome. Don’t worry, we all make this sort of mistake. :smiley:
