Problem when logging out of discourse and more
(@SenpaiMass) #1
Hello i am having problems logging out of discourse and also i am not able to delete a topic .
Site is http://greedgamer.com.
I am also not able to delete any of my topics :frowning: .
I have installed discourse using the official method on Digital ocean itself.
When i hit log out nothing happens, same goes for delete topic
(Jeff Atwood) #2
Are you attempting to use any plugins or anything outside the standard install?
If the answer is no, I suggest you take a backup and reinstall again from scratch.
(@SenpaiMass) #3
yea i did try the discourse adsense but uninstalled it. I think i need to re install :smile:
(@SenpaiMass) #4
@codinghorror Did a fresh install with backup still same issue :frowning:
(@SenpaiMass) #5
So i have done a reinstall yet again and the same issue as of now , not able to log out nor delete any topics.
Using a complete fresh install on digital ocean 2gb server, Installation method is official
Edit:
a lot of functionality such as deleting forums also does not work.
I am using a complete fresh install. cleared my cache ctrl+shift+r removed my cookies and when i log back in same stuff cant logout. :frowning:
(Ben T) #6
Is any information printed to the /logs when you try to log out? You should be able to access it while logged in as an admin user by appending /logs to your base url.
(@SenpaiMass) #7
My Complete logs
(Ben T) #8
Okay, is any information printed to your javascript console when you try to log out? Here’s some information on inspecting it in various browsers:
(@SenpaiMass) #9
@trident
reflow: 0ms
reflow: 0ms
reflow: 0ms
reflow: 0ms
reflow: 0ms
POST HugeDomains.com - Shop for over 300,000 Premium Domains [HTTP/1.1 200 OK 15114ms]
DELETE HugeDomains.com - Shop for over 300,000 Premium Domains [HTTP/1.1 403 Access Denied 0ms]
POST HugeDomains.com - Shop for over 300,000 Premium Domains [HTTP/1.1 200 OK 90ms]
syntax error report_js_error:1
DELETE HugeDomains.com - Shop for over 300,000 Premium Domains [HTTP/1.1 403 Access Denied 16ms]
And on my Opera Browser
Failed to load resource: the server responded with a status of 403 (Access Denied) HugeDomains.com - Shop for over 300,000 Premium Domains HugeDomains.com - Shop for over 300,000 Premium Domains 403 (Access Denied) vendor-4664ad0a0dfeced57591db8ed993931c.js:4
(Ben T) #10
Another check; can you register a new user and post topics? Do you have another computer to connect from to do this?
(@SenpaiMass) #11
@trident @codinghorror
Yea i just did that
http://greedgamer.com/t/test-topic-for-the-bug-or-whatsoever/9/1
Edit :
Is this a discourse bug ??
2nd Edit :
Uploaded my backup :frowning: and still the functionality not working
(lid) #12
Can you try clearing your cookies.restart your browser. And sign in again.
(@SenpaiMass) #13
i have already done that and infact did this now , same issue.
(@SenpaiMass) #15
Completely Clueless and helpless any one can put me out of my misery and tell me what is wrong with the discourse installation that i have done.?
Edit : I have followed a clean official installation on digital ocean 2gb server.
Still this problem persists.
Edit IP : 178.62.60.4
(Jens Maier) #16
Are you using SSL? Is your HTTP traffic being forced through a transparent proxy server (on your client side, not on the Discourse server side)? Are you using a caching proxy?
Something is blocking all the DELETE requests and, if you followed the instructions, that’s most likely not Discourse’s doing.
(@SenpaiMass) #17
I have followed the discourse instructions around 20 times, i have installed it around 20 times with the same instructions.
I am not using SSL, my HTTP traffic is not being forced through a transparent proxy server
(Jens Maier) #18
I still find it highly suspicious that your browser’s javascript console shows 403 Access Denied for each and every DELETE request.
Can you check that the /var/docker/shared/log/rails/unicorn.stderr.log file actually reflects these failed requests? Look for lines like this:
192.168.xx.yy - - [19/Jul/2014 01:35:18] “DELETE /session/Username HTTP/1.1” 200 - 0.0231
(@SenpaiMass) #19
So confused atm here is my unicorn.stderr.log file
I, [2014-07-21T14:02:00.597378 #59]  INFO – : Refreshing Gem list
I, [2014-07-21T14:02:07.601159 #59]  INFO – : listening on addr=0.0.0.0:3000 fd=14
Loading Sidekiq in process id 84
I, [2014-07-21T14:02:10.219323 #136]  INFO – : worker=0 ready
I, [2014-07-21T14:02:11.224447 #185]  INFO – : worker=1 ready
I, [2014-07-21T14:02:12.224793 #59]  INFO – : master process ready
I, [2014-07-21T14:02:12.229987 #201]  INFO – : worker=2 ready
find: `/var/www/discourse/public/tombstone/default’: No such file or directory
From GitHub - discourse/discourse: A platform for community discussion. Free, open, simple.
   499f18a…8bde019  tests-passed -> origin/tests-passed
   9c2a7f0…8bde019  master     -> origin/master
I, [2014-07-21T14:24:23.993234 #2271]  INFO – : executing ["/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/un$
I, [2014-07-21T14:24:23.993607 #2271]  INFO – : forked child re-executing…
I, [2014-07-21T14:24:25.168611 #59]  INFO – : reaped #<Process::Status: pid 84 exit 0> worker=unknown
Detected dead worker 84, restarting…
Loading Sidekiq in process id 2276
I, [2014-07-21T14:24:34.381306 #59]  INFO – : reaped #<Process::Status: pid 136 exit 0> worker=0
I, [2014-07-21T14:24:34.381650 #59]  INFO – : reaped #<Process::Status: pid 185 exit 0> worker=1
I, [2014-07-21T14:24:34.381829 #59]  INFO – : reaped #<Process::Status: pid 201 exit 0> worker=2
I, [2014-07-21T14:24:34.381984 #59]  INFO – : master complete
(Jens Maier) #20
Uuuh, did you rebuild the container and then post the log file without trying to log out or delete a post or topic? :confused:
(@SenpaiMass) #21
No i did not rebuild the container. i checked the log file after i tried to delete a post or topic or even logout.
I can provide server / admin details if needed.
