Problem with file attachments
#1
Good day,
We are having problems with user-uploaded file attachments disappearing. The files will appear for a while and then start returning 404s. I have not yet determined how/when they disappear, the one I’m specifically looking at right now was posted 12/17/2017.
The url looks right, like this, but the server returns a 404:
/forum/uploads/default/original/1X/87e1ab068c9032f0d67d3fc004ff72c4d4a7aaed.jpg
I just tried adding a picture to a post, and it’s displaying correctly. The url for that image (that returns a 200) is this:
/forum/uploads/default/original/1X/3010fecd22455b030e3aca1fe64cce64de9a335d.jpeg
(we use a subfolder installation)
I have multiple questions:
  1. What might cause the pictures to “go missing”, and how can I troubleshoot / fix?
  2. I’ve been having random problems with user uploaded images not working. Would you recommend moving to a subdomain installation instead of a subfolder install (it doesn’t seem to be the issue since it appears that the actual file is missing and not that there is a problem with the URL).
  3. Would it be more stable to move to using S3 for user images? This post by @codinghorror suggests that it’s NOT a good idea:
But then this later post by @zogstrip says that the meta site’s images WERE moved to S3:
Suggestions?
Thank you,
Stephen
(Alan Tan) #4
You can try running the following commands to see which uploads are missing:
./launcher enter app
rake uploads:missing
Once you have an idea of what is missing, you can try to look for them in the tombstone folder /var/www/discourse/public/uploads/default/tombstone.
#5
Thanks @tgxworld. I’ll take a look at that.
Any suggestions on why this would be happening and/or if we would have more or less problems if I moved uploads to S3?
(Jay Pfaffman) #6
In the meantime, you might set
SiteSetting.clean_up_uploads=false
That will keep more images from getting deleted (though it increases the chance that someone will use your site to serve images you don’t want them do).
#7
I have the same problem - did you ever manage to solve it?
(Jay Pfaffman) #8
Some changes were made in the last few days that should solve what may be your problem.
Upgrade and see Images are disappearing off of s3!
