# Sitemap issue
**URL:** https://meta.discourse.org/t/probleme-de-sitemap/394642
**Category:** Bug
**Tags:** sitemap
**Created:** [January 29, 2026, 11:13am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642 "2026-01-29T11:13:36Z")
**Posts on this page:** 6
**Page:** 1
<div class="post-metadata">
### Author: ![Antoinnne](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/antoinnne/32/540852_2.png) [@Antoinnne](https://meta.discourse.org/u/Antoinnne)
#### Post date: [January 29, 2026, 11:13am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/1 "2026-01-29T11:13:37Z")
</div>
I don’t know if it’s a bug or if I misconfigured the sitemap, but I keep getting an error and I can’t fix it.
When I submit my sitemap ([https://join-nexus.ovh/sitemap.xml](https://join-nexus.ovh/sitemap.xml))
I get an error, screenshot below, Google cannot retrieve the sitemap and says the type is unknown.
I tested:
lots of curl commands which all return 200 - Google can access the sitemap
a sitemap validator that checks if my sitemap is valid, which it is [https://www.xml-sitemaps.com/validate-xml-sitemap.html](https://www.xml-sitemaps.com/validate-xml-sitemap.html)
removing and re-adding my Sitemap changes nothing
using alternative sitemaps ([https://join-nexus.ovh/sitemap\_1.xml](https://join-nexus.ovh/sitemap_1.xml), [https://join-nexus.ovh/sitemap\_recent.xml](https://join-nexus.ovh/sitemap_recent.xml)) but that doesn’t work either, same error
 ![image](https://global.discourse-cdn.com/meta/original/4X/f/5/1/f5183a0505b5d84edff6a6b881d5a4b5d5ccff7f.png)
I don’t know how to solve this problem, especially since the sitemap is a super important feature.
I can still index the links individually by hand and Google indexes them, I really don’t understand.
Thanks in advance for your help.
### Author: ![NateDhaliwal](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/natedhaliwal/32/313494_2.png) [@NateDhaliwal](https://meta.discourse.org/u/NateDhaliwal)
#### Post date: [January 29, 2026, 11:20am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/2 "2026-01-29T11:20:05Z")
</div>
If you click into the sitemap info, does that provide any more details about the error?
#### Post date: [January 29, 2026, 11:21am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/3 "2026-01-29T11:21:22Z")
</div>
no, sorry
 ![image](https://global.discourse-cdn.com/meta/original/4X/e/d/d/edd335452e0e0cb4a1bfcf12564039a2f135a5b0.png)
#### Post date: [January 29, 2026, 11:42pm UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/4 "2026-01-29T23:42:25Z")
</div>
please someone help me 🥲
### Author: ![Canapin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/canapin/32/119591_2.png) [@Canapin](https://meta.discourse.org/u/Canapin)
#### Post date: [January 30, 2026, 12:39am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/5 "2026-01-30T00:39:41Z")
</div>
Please be patient. It’s a forum, and it goes as its own pace 🙂
Unless you have a budget and are willing to pay someone to have a look quickly though #Marketplace, people here do help on their free time 🙂
#### Post date: [February 2, 2026, 11:32am UTC](https://meta.discourse.org/t/probleme-de-sitemap/394642/7 "2026-02-02T11:32:28Z")
</div>
Hello everyone, Update, I found a way to add the sitemap but it require to really think outside the box
I had to create an external sitemap on this website
> **[PRO Sitemaps - Powerful and easy way to create, host and automatically...](https://pro-sitemaps.com)**
> PRO Sitemaps. Automatically create, host and keep up to date XML sitemaps - a hassle-free professional sitemap service provided by PRO-Sitemaps.com
Once this sitemap was indexed by google on its own domain on the search console
I got this message on my own domain on the search console
 ![image](https://global.discourse-cdn.com/meta/original/4X/7/9/3/7932366c286910020161afaa440f9ac0795f2b40.png)
So google started indexing the pages
My sitemaps still don’t work from my own domain but it may be because of my .ovh domain name
I hope this helps
