Problems in response quote
When I go to answer someone, it doesn’t look like that
but like that
I’ve already gone into options and changed a lot of things, but it’s still like that! It’s bad for people to see what others are replying or quote, how do I fix it?
This is the way Discourse is designed to work. If you click the “Reply” button on a post and write your message, it will do what you’ve indicated since you’re replying to the post as a whole. If you want to quote someone and reply to that, select the text you want in their post and hit the “Quote” button that pops up.
To create something like your screenshot example, first I select the text above in your message and click quote as @sdpiowa described. This starts a new reply with that quote.
With my reply still open, next I select the text above from @sdpiowa’s reply and click quote again, which appends it to my reply. It doesn’t even have to be from here, I could navigate somewhere else and select a quote from a separate topic.
