Problems with mailcatcher in dev environment
(Gerhard Schlager) #1
I’ve setup my development environment according to this howto:
Up until now I could receive mails using mailcatcher. Today I noticed that mails sent by Discourse do not work anymore. I see the following error in the Sidekiq dashboard:
Jobs::HandledExceptionWrapper: Wrapped Net::ReadTimeout: Net::ReadTimeout
Sending mails using telnet works and they show up in mailcatcher.
Any thoughts what could be wrong and how I could fix this?
I’m not aware of any changes I made except of pulling Discourse master.
Beginners Guide to Install Discourse on Ubuntu for Development
(Jeff Atwood) #2
Any ideas on this @techapj?
(cpradio) #3
Just want to say I’m having this issue too. I’ve had it happening over a week and thought it was my setup…
(Arpit Jalan) #4
Just tested, can confirm this is happening. Looking into it.
(Gerhard Schlager) #5
I hope you’ll find a solution soon.
Is there a workaround so that I can activate new users in my dev environment? The following doesn’t work since it still expects me to validate the account by clicking on a link in the email I didn’t get. :frowning:
RAILS_ENV=development bundle exec rails c
u = User.last
u.admin = true
u.save
(Robin Ward) #6
I spent some time on this today and confirmed we’re seeing this bug:
https://github.com/sj26/mailcatcher/issues/182
Seems to be a bug in mailcatcher itself. The workaround until they release an update is to run it in the foreground instead (-f option).
Beginners Guide to Install Discourse on macOS for Development
(Robbo) #7
Is there a better fix for this yet? Same issue for me (and solution) as of writing.
(Gerhard Schlager) #8
There’s a new version of mailcatcher which fixes this problem:
(S4 Kh) #9
Mailcatcher is still not working. Even with updated version (0.6.1)
Alternate solution:
  1. Access to your email_tokens table
  2. Copy value in the token column which is in the same row as your username
  3. Paste http://localhost:3000/users/activate-account/your_token_value on your browser address bar
  4. Will able to activate your account
(Gerhard Schlager) #10
Not true. It’s working fine since 0.6.0.
What error are you getting? Is sidekiq running?
