Problems with markdown formatting
markdown
(drogus) #1
When I’m adding a post on ember’s discourse instance, the code is formatted properly in the preview, but when the post is saved and after refresh, a formatting is broken.
Here is a code from the post:
{{#if loading}}
  List is loading
{{else}}
  display list
{{/if}}
<ul class="posts">
  {{#each post in controller}}
    <li>{{post.title}}</li>
  {{/each}}
</ul>
{{outlet}}
{{#resource "posts"}}
  <ul class="posts">
    {{/each}}
  </ul>
{{/resource}}
{{outlet}}
(drogus) #2
I should probably also mention that adding extra newlines helps:
{{#if loading}}
  List is loading
{{else}}
  display list
{{/if}}
<ul class="posts">
  {{/each}}
</ul>
{{outlet}}
  <ul class="posts">
    {{/each}}
  </ul>
{{/resource}}
{{outlet}}
(Bill Ayakatubby) #3
I suggest indenting each line by 4 spaces, e.g.
{{#if loading}}
  List is loading
{{else}}
  display list
{{/if}}
<ul class="posts">
  {{/each}}
</ul>
{{outlet}}
  <ul class="posts">
    {{/each}}
  </ul>
{{/resource}}
{{outlet}}
(Sam Saffron) #4
Yes, this looks like a bug, @eviltrout ?
(Robin Ward) #5
Okay this is super confusing. I see your malformed markup, but when I edited it to change it without adding whitespace to the code blocks it worked perfectly. See the OP now!
I rolled back git code and it still works. Can you confirm it’s fixed or any way to reproduce it please? thanks!
(Jeff Atwood) #6
Is this still an issue or should this be deleted?
(drogus) #7
Testing in the new post, just to be sure:
{{#if loading}}
  List is loading
{{else}}
  display list
{{/if}}
<ul class="posts">
  {{/each}}
</ul>
{{outlet}}
  <ul class="posts">
    {{/each}}
  </ul>
{{/resource}}
{{outlet}}
(drogus) #8
It seems to work great!
(Jeff Atwood) #9
