Provide more settings to be overridden in GlobalSetting
(Dan Porter) #1
I used to use
openssl_verify_mode  => 'none'
for my SMTP config in discourse. Now, with the settings being passed through from that of GlobalSetting, I am reluctant to make changes in favour of this centralised (or not :wink:) configuration file.
It would be cool if discourse added a few more (or possibly all) settings for any module that uses GlobalSetting, which doesn’t necessarily need documented in the default discourse.conf.
(Sam Saffron) #2
sure, fine to add this, PR please?
Note, I don’t want to imagineer new settings, lets add them as we need them.
(Dan Porter) #3
Yeah I’ll submit this later, thanks!
(Ricardo Marques) #4
@stealthii did you submit it ?
(Dan Porter) #5
I did not, this fell off my tasklist for some reason. If I get round to this I’ll update here, but it’s a low priority feature.
(Claus Strasburger) #6
https://github.com/discourse/discourse/pull/2322
there you go :slight_smile:
