Putting custom CSS on CDN as well
cdn
(Resurrectedstar) #1
Is there a way to put the custom/all CSS on the CDN as well?
I have noticed during load testing that all css files are fetched from the forum, rather than the CDN site.
The CDN is set to https://forums.cdnserv.sandydprod.net (you may have to set the URLs to show 50 at a time).
Then, scroll to the bottom and under URL content type load time distribution, and click on the text/css slice.
Scroll back up, and you will now see all the CSS urls highlighted - which are all served from the forum instead of the CDN
(Sam Saffron) #2
Going to recategorize this as a bug for now, it should be automatic.
(Jeff Atwood) #3
If this is a bug you should see it on http://discourse.codinghorror.com which is using CDN77. Do you see it there too?
(Sam Saffron) #4
I see it on BBS, known about it for a while … we should fix
(Jeff Atwood) #5
Oh this is the custom override CSS. That’s probably quite small, and won’t affect a default Discourse install. I don’t think discourse.codinghorror.com even has any custom CSS.
(Sam Saffron) #6
This is now fixed:
https://github.com/discourse/discourse/commit/b2e29526ff233ade8bb6a988482e152bb740b0a7
(Sam Saffron) #7
