Question about how you composed a past post
Hi Erlend
I have very recently set up a Discourse forum and am in the process of configuring it. I came across this post of yours from several years ago which I admire not only for its content but also in particular for its wonderfully easy to read style:
Can I ask what software you used to compose this - particularly your lists with coordinated icons, fonts, and hyperlinks? Is this using a Discourse plugin or some external HTML editor?
It’s all standard Discourse :slight_smile: Here’s the raw Markdown file:
https://meta.discourse.org/raw/36432
Very interesting and impressive - I must say you have motivated me to master Markdown. I am going to review the Commonmark learning materials in detail!
Question - for parts of the document such as this do you use a text expander or do you literally type out the Markdown like this?
:white_check_mark: = Done
:hammer: = WIP
:thought_balloon: = Tentative
:no_entry_sign: = Discarded (for the time being)
Also where can I find a comprehensive list of Markdown shortcuts? For example, I thought this document would be comprehensive but I do not see the above 4 items listed in it - where are they documented?
https://spec.commonmark.org/0.28/#example-29
Sometimes I just type a : and start typing if I know what I’m looking for. Otherwise I’ll just use the smiley widget in the editor.
They are not part of the Markdown/CommonMark spec, they’re custom emoji codes.
p.s. I converted this to a public post so everyone can benefit from these general purpose questions.
