Quick Question : Topic Auto Close / Banner
(Rob Meade) #1
Hi all,
If I have a topic set as a banner will setting the auto close date/time also make the banner disappear, or does that always require admin intervention to un-banner-ise it?
Thanks in advance.
(cpradio) #2
Fairly certain it will remain a banner.
(Rob Meade) #3
Hi @cpradio,
Thanks for the response, appreciated.
That was my feeling. I take it there isn’t anything else which automatically stops the banners?
We typically use them for announcements relating to a promotion, so they have a valid reason for being removed, I have been doing it manually, but when an offer ends at midnight it means I have to stay up! :tired_face:
If there isn’t anything like this at the moment, do you think it would be worth putting it forwards as a suggestion? No point if you don’t feel it has value.
(Dean Taylor) #4
You could always schedule a command similar to the following to be executed:
  • at the right time
  • on a computer that doesn’t fall to sleep
  • with a good internet connection
curl -X PUT -d api_key=YOUR_API_KEY_GOES_HERE -d api_username=API_USERNAME_HERE http://discourse.example.com/t/YOUR_TOPIC_ID_GOES_HERE/remove-banner
(Jeff Atwood) #5
Why not just put the text “this offer ends at midnight UTC” in the banner text?
(Rob Meade) #6
Yes, could do that, already have those details bar the UTC etc. Just feels like as there is already automation around the closing of topics, that if they have been pinned or set as a banner, an option to unpin/remove banner would make sense too.
Bit of a cleaner/tidier experience for the users not still seeing things which are no longer valid (fully appreciating I could just stay up and remove it when it expires).
I tend to also make the posts which are for banners unlisted, e.g. its just an announcement that we want to show across the top of the screen, not necessarily as a specific topic in the list, which gets shuffled down through the “Latest Topics” view really quickly anyway. Can only set it as a banner if it is listed though, so harder to set a banner without displaying the topic (briefly) first.
Again, maybe just the way I’m using it but thought I’d mention it.
Thanks as always for the responses :slight_smile:
