Rails Console Error: FATAL: Peer authentication failed for user "discourse"
(Chris Croome) #1
Sorry to ask a basic question which is similar to other threads, but I couldn’t find a thread that had a solution to this, also sorry if I’m doing something daft here (it wouldn’t be the first time ;-)).
On a Debian Stretch server running the standalone Docker Discourse I’m getting an error when trying to use the Rails console, this is what is happening:
ssh root@example.org
su - discourse
cd /var/discourse
./launcher enter app
rails c
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.20.0/lib/pg.rb:56:in `initialize': FATAL:  Peer authentication failed for user "discourse" (PG::ConnectionBad)
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.20.0/lib/pg.rb:56:in `new'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.20.0/lib/pg.rb:56:in `connect'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:695:in `connect'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:220:in `initialize'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:38:in `new'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:38:in `postgresql_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:759:in `new_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:803:in `checkout_new_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:782:in `try_to_checkout_new_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:743:in `acquire_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:500:in `checkout'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:374:in `connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:931:in `retrieve_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_handling.rb:116:in `retrieve_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_handling.rb:88:in `connection'
        from /var/www/discourse/lib/site_settings/db_provider.rb:62:in `table_exists?'
        from /var/www/discourse/lib/site_settings/db_provider.rb:21:in `find'
        from /var/www/discourse/lib/site_settings/defaults_provider.rb:109:in `block in refresh_site_locale!'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-1.1.0.rc4/lib/rails_multisite/connection_management.rb:126:in `block in each_connection'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-1.1.0.rc4/lib/rails_multisite/connection_management.rb:124:in `each'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-1.1.0.rc4/lib/rails_multisite/connection_management.rb:124:in `each_connection'
        from /var/www/discourse/lib/site_settings/defaults_provider.rb:103:in `refresh_site_locale!'
        from /var/www/discourse/lib/site_settings/defaults_provider.rb:20:in `initialize'
        from /var/www/discourse/lib/site_setting_extension.rb:35:in `new'
        from /var/www/discourse/lib/site_setting_extension.rb:35:in `defaults'
        from /var/www/discourse/lib/site_setting_extension.rb:69:in `block in setting'
        from /var/www/discourse/lib/site_setting_extension.rb:68:in `synchronize'
        from /var/www/discourse/lib/site_setting_extension.rb:68:in `setting'
        from /var/www/discourse/app/models/site_setting.rb:17:in `block in load_settings'
        from /var/www/discourse/lib/site_settings/yaml_loader.rb:25:in `block (2 levels) in load'
        from /var/www/discourse/lib/site_settings/yaml_loader.rb:11:in `each'
        from /var/www/discourse/lib/site_settings/yaml_loader.rb:11:in `block in load'
        from /var/www/discourse/lib/site_settings/yaml_loader.rb:10:in `each_key'
        from /var/www/discourse/lib/site_settings/yaml_loader.rb:10:in `load'
        from /var/www/discourse/app/models/site_setting.rb:16:in `load_settings'
        from /var/www/discourse/app/models/site_setting.rb:21:in `<class:SiteSetting>'
        from /var/www/discourse/app/models/site_setting.rb:4:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `require'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `block in require'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:258:in `load_dependency'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:379:in `block in require_or_load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:36:in `block in load_interlock'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:12:in `block in loading'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/concurrency/share_lock.rb:149:in `exclusive'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:11:in `loading'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:36:in `load_interlock'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:357:in `require_or_load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:510:in `load_missing_constant'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:202:in `const_missing'
        from /var/www/discourse/config/initializers/004-message_bus.rb:84:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:286:in `load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:286:in `block in load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:655:in `block in load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:168:in `instrument'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:654:in `load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:612:in `block (2 levels) in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:611:in `each'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:611:in `block in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `run'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:59:in `block in run_initializers'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:228:in `block in tsort_each'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:431:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:48:in `each'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:48:in `tsort_each_child'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:415:in `call'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:415:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:349:in `block in each_strongly_connected_component'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:347:in `each'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:347:in `call'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:347:in `each_strongly_connected_component'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:226:in `tsort_each'
        from /usr/local/lib/ruby/2.4.0/tsort.rb:205:in `tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:58:in `run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:353:in `initialize!'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
        from /var/www/discourse/config/environment.rb:5:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:329:in `require_environment!'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/command/actions.rb:16:in `require_application_and_environment!'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/console/console_command.rb:96:in `perform'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/thor-0.19.4/lib/thor/command.rb:27:in `run'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/thor-0.19.4/lib/thor/invocation.rb:126:in `invoke_command'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/thor-0.19.4/lib/thor.rb:369:in `dispatch'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/command/base.rb:63:in `perform'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/command.rb:44:in `invoke'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands.rb:16:in `<top (required)>'
        from bin/rails:4:in `require'
        from bin/rails:4:in `<main>'
So I thought I’d try as the discourse user in the container rather than root, in the container:
su - discourse
cd /var/www/discourse/
rails c
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:699:in `rescue in connect': FATAL:  database "discourse_development" does not exist (ActiveRecord::NoDatabaseError)
        from /var/www/discourse/app/models/site_setting.rb:4:in `<main>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:63:in `load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:476:in `block in load_file'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:661:in `new_constants_in'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:475:in `load_file'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:374:in `block in require_or_load'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:53:in `block in load_missing_constant'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:6:in `with_bootsnap_fallback'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:53:in `load_missing_constant'
        from /var/www/discourse/config/initializers/004-message_bus.rb:84:in `<main>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `load'
        from /var/www/discourse/config/environment.rb:5:in `<main>'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:17:in `require'
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands.rb:16:in `<main>'
Any suggestions?
(Daniela) #2
I have no problems on Ubuntu with:
cd /var/discourse
rails c
without using su - discourse
(Chris Croome) #3
Thanks @Trash but the discourse user on the server is in the docker group so that shouldn’t make a difference, and it doesn’t appear to:
cd /var/discourse
rails c
(Chris Croome) #4
Does anybody have any suggestions regarding how to debug this problem?
(Mittineague) #5
There is obviously a problem that involves the database.
What happens if you do rails db instead of rails c ?
(Chris Croome) #6
You are right:
rails db
        from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/dbconsole/dbconsole_command.rb:154:in `perform'
(Chris Croome) #7
The site appears to be working fine, nothing appears to be wrong when using the web interface, it’s a new server and install with a massive (1+ million posts, 13k user) database that was migrated from vBulletin.
(Chris Croome) #8
I know my way around MySQL / MariaDB fairly well, I’m afraid I have less Postgres experience (the same can be said of Ruby, Rails and Docker) — can anyone suggest some steps I could take to track down the cause of this issue?
(Michael Brown) #9
Note the different errors:
root tried to connect via the Unix domain socket (hence peer authentication) and PG rejected root
discourse successfully connected to PG, however the (development) database to which it tried to connect doesn’t exist. You might need:
RAILS_ENV=production rails c
(Mittineague) #10
I don’t know how you set things up, but AFAIK “discourse” is the owner of the database.
Maybe you need to create the SUPERUSER ?
This is for a development setup, so you should probably go over whatever steps you followed, but it may help.
(Chris Croome) #11
Thanks for the suggestion, this is what I get:
All the envars:
printenv
HOSTNAME=example-app
LETSENCRYPT_ACCOUNT_EMAIL=chris@webarchitects.co.uk
DISCOURSE_DB_HOST=
TERM=xterm
RUBY_GLOBAL_METHOD_CACHE_SIZE=131072
DISCOURSE_DEVELOPER_EMAILS=chris@webarchitects.co.uk
PG_MAJOR=9.5
OLDPWD=/
LETSENCRYPT_DIR=/shared/letsencrypt
RUBY_ALLOCATOR=/usr/lib/libjemalloc.so.1
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
DOCKER_HOST_IP=172.17.0.1
PWD=/var/www/discourse
RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000
RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5
DISCOURSE_SMTP_ADDRESS=example.webarchitects.co.uk
LANG=en_GB.UTF-8
DISCOURSE_HOSTNAME=example.webarchitects.co.uk
RUBY_GC_HEAP_INIT_SLOTS=400000
UNICORN_WORKERS=16
SHLVL=1
HOME=/root
UNICORN_SIDEKIQS=1
DISCOURSE_DB_PORT=
COMPRESS_BROTLI=1
DISCOURSE_DB_SOCKET=/var/run/postgresql
_=/usr/bin/printenv
I assume not having DISCOURSE_DB_PORT isn’t a problem is it is using sockets?
(Chris Croome) #12
The discourse user and group exists in the container:
cat /etc/passwd | grep discourse
discourse:x:1000:1000::/home/discourse:/bin/bash
cat /etc/group | grep discourse
discourse:x:1000:
Or am I misunderstanding your suggestion?
One thing I found I had to do during the database migration was add this to /etc/sudoers:
discourse ALL = NOPASSWD: ALL
But I can’t think of any other changes that could be causing this.
Regarding the Beginners Guide to Install Discourse on Ubuntu for Development, I’m not sure how applicable that is to my situation, the site is running on a 8 core, 32GB RAM VPS I installed using Ansible playbooks which follow the official install steps for a standalone server / Docker etc.
(Chris Croome) #13
I backed the site up, transferred the 910M backup to a brand new VPS with a fresh Discourse install and imported it and now the Rails console works without a problem :slight_smile:
Sorry not to have tried that before creating this thread but perhaps if someone else has this problem in future this might help them.
