Re importing data after migration
(Ricardo Viteri) #1
Continuing the discussion from After migrating from Vanilla all users display a random post in their '“about me” section:
@zogstrip, Is it possible to re-import and replace all forum data or would a new install be required ?
How to execute db:drop db:create db:migrate?
(Régis Hanol) #2
Imports are resumable so if you want a brand new forum. you first need to drop the database and create a new one.
(Ricardo Viteri) #3
Can you tell me how to do this? What commands I need to execute?
Thanks!
(Régis Hanol) #4
Here’s the command you can execute if you want to reset your database: bundle exec rake db:drop db:create db:migrate.
(Ricardo Viteri) #5
Great. So as I understand it, I would execute this command and then follow the importer instructions. Am I right?
(Régis Hanol) #6
:point_up: Exactly :point_up:
