Re processing imported posts
(Dean Taylor) #1
I would like to re process all imported posts (700,000 + posts) …
Basic problem was that a super large number of images were from photobucket but the import process didn’t handle them correctly.
Where code like this:
[URL=http://s662.photobucket.com/user/jinzin2008/media/thWolverine_51_013.jpg.html][IMG]http://i662.photobucket.com/albums/uu345/jinzin2008/thWolverine_51_013.jpg[/IMG][/URL]
Was turned into this:
http://s662.photobucket.com/user/jinzin2008/media/thWolverine_51_013.jpg.htmlhttp://i662.photobucket.com/albums/uu345/jinzin2008/thWolverine_51_013.jpg
So photobucket is the easy ones to handle because of the similarity of the URL’s - so I’ll tackle that one first and then look for other broken items.
… basically I would like loop over all posts (PM’s, forum content) and:
  • Run a regular regex replace creating a new in-memory string (revised_content) based on the latest revision (original_content)
  • If revised_content is different to the original_content
  • Add new revision with revised_content
  • This action should not bump the topics activity date.
Just wondering if anybody has done this kind of thing already and has a code-snippet or two to point me at before I get started?
(Michael - DiscourseHosting.com) #2
Yes, we encountered the EXACT same issue, even the HTML/bbCode looked the same as yours.
I will post our ‘fix’ script later today. We didn’t use revisions though, just regex on raw and then a rebake.
(Michael - DiscourseHosting.com) #3
Ok.
First go into the database and issue the following SQL query
update posts set raw=regexp_replace(raw, '(http://[^\.]*\.photobucket.com[^\]]*)\]\[img\]([^\[]*)\[\/img', '\1', 'g');
Then get a command prompt and
bundle exec rails c
Post.where("cooked like ?","%photobucket%").find_each do |post|
   post.rebake!
   puts "X"
   sleep 2
I had to put the sleep in there to avoid Photobucket getting annoyed and Sidekiq queuing up a lot. But maybe you don’t need that.
(Dean Taylor) #4
Thanks for providing what you have @michaeld
However your regular expression doesn’t actually match what I have in my posts.
I have:
Whilst you seem to be matching the original bbcode version.
(Michael - DiscourseHosting.com) #5
Ok. Well… important lesson: you need to keep the .html part, not the jpg. If you leave it in the post on a single line, oneboxing will do the rest.
So you need a regex for that. I think
(http:\/\/[^\.]*\.photobucket.com[^\.]*\.jpg.html)http:\/\/[^\.]*\.photobucket.com[^\.]*\.jpg
will do.
(Dean Taylor) #6
Thanks for the feedback @michaeld I’ll report back what I end up doing.
