Re-start previous container
(Jay Pfaffman) #1
The last line of a ./laucher rebuild app has the docker command that cranks up the container. If you subsequently do a rebuild and it fails due to a bad plugin or whatever, you’re sort of stuck. Is there some way to re-start the previously running container and deal with the rebuild later on?
(David Taylor) #2
If it fails during the bootstrap step, then you can just run
./launcher start app
and it’ll start what you had before you did the rebuild.
Whether that’s guaranteed to work 100% of the time, I’m not sure.
How do you revert to previous containers?
(Jay Pfaffman) #3
No. Really? And I’ve been doing this for over two years . . .
