Read More links in Email
My Read More URL is pointing to https://domain.com:80/path
I want to remove the :80 in that URL. Where do I customize this URL that is set in Read More of the emails that discourse sends?
TIA.
Sounds like you have a bum install. Did you install using our official install guide. Discourse only works on the official HTTPS/HTTP ports.
My installation of discourse is over 3 years old. I switched from http from https, and this happens when I try to set force_https in the settings. If that force_https unselected, the “Read More” links in emails are fine.
Is there a chance you’re running behind a reverse proxy of sorts?
How did you install three years ago? Did you follow the official guide?
Yes, I followed the official guide.
If I go to my server, I see the docker instance running like this.
# docker ps
CONTAINER ID        IMAGE                 COMMAND             CREATED             STATUS              PORTS                                        NAMES
199f1145dc33        local_discourse/app   "/sbin/boot"        6 weeks ago         Up 6 weeks          0.0.0.0:2222->22/tcp, 0.0.0.0:8090->80/tcp   app
How and where is the link to “Read More” in the emails set? Why did it add to :80 when force_https is set. I don’t know.
Like @itsbhanusharma suggested, the problem is likely in whatever is reverse proxying to port 8090 and is handling https.
What is the output of
netstat -alpn | grep 80
On the Host machine
Hi @itsbhanusharma - Sorry, I missed your question.
Yes, I am serving the site through ngnix.
root@www:~# netstat -alpn | grep 80
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1016/nginx
https is handled by nginx which has letsencrypt certs loaded.
Can you share your nginx config here? Redact any personal information.
Does your discourse get the correct ip addresses or that of the nginx?
Follow this to check a few things:
