Rebuild app failed with 'UPGRADE OF POSTGRES FAILED'
Hello!
My website is down after restart server.
I try to cleanup and run ./launcher rebuild app but failed with Run "./launcher rebuild app" - Pastebin.com
It seems that PostgreSQL couldn’t auto upgrade from 9.5 to 10.
Then I follow the instructions in this template. But after I change “templates/postgres.template.yml” to “templates/postgres.9.5.template.yml”’ and Run ./launcher rebuild app again, I got another failed with Run "./launcher rebuild app" again - Pastebin.com.
I spent hours searching this problem and found some similar problems, but always failed after rebuild app and got same error like Run "./launcher rebuild app" again - Pastebin.com
psql: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
Help anyone?
Thanks!
Did you get this working?
