Rebuild error - color_schemes.versioned_id does not exist
#1
I was trying to setup letsencrypt for my discourse install, and launcher rebuild app fails with the error:
2017-05-09 18:12:54 UTC [3532-1] discourse@discourse ERROR:  column color_schemes.versioned_id does not exist at character 54
2017-05-09 18:12:54 UTC [3532-2] discourse@discourse STATEMENT:  SELECT  "color_schemes".* FROM "color_schemes" WHERE "color_schemes"."versioned_id" IS NULL AND "color_schemes"."enabled" = 't' LIMIT 1
rake aborted!
My discourse install is now down:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 3518 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
31813b80be2800059c2d90f22c42584beb0e2b735e612f028da57db8dc44010e
I’ve searched the output of launcher rebuild app and from what I can tell, that postgres error is the only one, how could I go about fixing this?
Note: in /var/discourse, a git pull shows Already up-to-date.
(Sam Saffron) #2
Have you tried to downgrade beta to stable?
#3
Thanks for your quick response, hm. I can look into it but am a bit concerned due to your warnings in this thread:
As I’m unable to connect to the admin, is there a way to check the version to see if this is even possible?
Also, oddly enough, my app.yml file shows version: stable
(Sam Saffron) #4
Sounds to me like you changed it recently, my recommendation is to change it to beta and rebuild.
#5
That did the trick, sam! Thanks for your help.
In any case, out of curiosity, is there a way to check the discourse version from the commandline?
(Sam Saffron) #6
enter container and run git log on discourse… something like that.
