Rebuild Failing due to Postgres DB corruption
(Resurrectedstar) #1
Hi, I am getting a rebuild failure as of right now
/pups/lib/pups/exec_command.rb:85:in `spawn': cd /var/www/discourse && sudo -E -u discourse bundle exec rake db:migrate failed with return #<Process::Status: pid 285 exit 1> (RuntimeError)
    from /pups/lib/pups/exec_command.rb:55:in `block in run'
    from /pups/lib/pups/exec_command.rb:53:in `each'
    from /pups/lib/pups/exec_command.rb:53:in `run'
    from /pups/lib/pups/command.rb:6:in `run'
    from /pups/lib/pups/config.rb:85:in `block (2 levels) in run_commands'
    from /pups/lib/pups/config.rb:76:in `each'
    from /pups/lib/pups/config.rb:76:in `block in run_commands'
    from /pups/lib/pups/config.rb:75:in `each'
    from /pups/lib/pups/config.rb:75:in `run_commands'
    from /pups/lib/pups/config.rb:71:in `run'
    from /pups/lib/pups/cli.rb:31:in `run'
    from /pups/bin/pups:8:in `<main>'
Though this might be because I just moved this docker from another host, I am not sure.
(RĂ©gis Hanol) #2
We need more information/context to be able to help you out. Can you post the whole log? (remove any password beforehand)
(Resurrectedstar) #3
http://paste.ubuntu.com/7915045/
(RĂ©gis Hanol) #4
Hmm, the error seems to be
PG::Error: ERROR:  missing chunk number 0 for toast value 35420 in pg_toast_16571
Seems like your database is somewhat corrupted :frowning:
(Resurrectedstar) #5
Yikes!
And I don’t have any postgres experience to recover or delete the offending row, time to search the internet it seems :stuck_out_tongue:
(Jens Maier) #6
Luckily, this appears to be a common problem… :grin:
Get into Postgres:
cd /var/docker
./launcher enter app
sudo -u postgres psql discourse
Then run this SQL:
REINDEX TABLE pg_toast.pg_toast_16571;
VACUUM ANALYZE posts;
\q
And finally exit.
This should fix the errors you get during migration but the data in your database may have been permanently damaged.
(Kane York) #7
Note that there are multiple scenarios in which corrupted database values will make Discourse unusable, esp. w.r.t. constraints.
(Jens Maier) #8
True, however in this case the damage, if any, should be limited to a raw or cooked column entry.
