Rebuild fails with missing miniportile when rebuilding with `IMPORT=1 bundle install`
This is a slightly non-standard install and I haven’t tested it on a vanilla one yet, but this looks like there might be a bug well, I’m rebuilding another site that’s not failing…could it be that there are NO plugins?
I, [2021-06-28T13:56:20.754459 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
bundler: failed to load command: rake (/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake)
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/spec_set.rb:95:in `block in materialize': Could not find mini_portile2-2.5.3 in any of the sources (Bundler::GemNotFound)
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/spec_set.rb:90:in `map!'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/spec_set.rb:90:in `materialize'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/definition.rb:183:in `specs'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/definition.rb:252:in `specs_for'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/definition.rb:234:in `requested_specs'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/runtime.rb:91:in `block in definition_method'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/runtime.rb:20:in `setup'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler.rb:149:in `setup'
        from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/setup.rb:20:in `block in <top (required)>'
What is the plugin list?
Yup. No plugins. I just added one to see if that would fix it. Not sure if it’s something weird with my template that’s writing the yml file or if it’s the case that you can’t have zero plugins.
Now I have this:
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
  # no advanced plugins
  # custom plugins
          - git clone https://github.com/discourse/discourse-tooltips.git
and it’s still failing.
So do you want to share how exactly it is a
or should we keep guessing?
Well, sorry about that; the problem is this template:
# This template adds the 'mysql2' gem for import scripts depending on it
params:
  home: /var/www/discourse
hooks:
  after_bundle_exec:
    - exec:
        cd: $home
        cmd:
          - apt-get update && DEBIAN_FRONTEND=noninteractive apt-get install -y libmariadb-dev freetds-dev sqlite3 libsqlite3-dev less
          - su discourse -c 'bundle config unset deployment'
          - su discourse -c 'IMPORT=1 bundle install --no-deployment --path vendor/bundle --jobs 4 --without test development'
Sorry folks. . . . Something changed that it keeping my import template from doing a IMPORT=1 bundle install from running. It worked the last time I built an import container.
I guess one of these things is to blame:
