Rebuild upload links?
(Stephen Chung) #1
Is there a way to “rebuild” the uploads and post_uploads tables?
For example, I have a whole bunch of video files moved to tombstone for some reason. I have moved the files back, but I fear that they’ll get removed again.
I checked uploads and post_uploads and the records are no longer there. No idea as to cause. (Perhaps me using the Azure Blob Plugin is a reason).
So, if I know that an upload exists, how can I manually rebuild those records?
And how do I manually relink them via post_uploads so that they won’t be removed again?
Azure Blob Storage Plugin
(Régis Hanol) #2
Rebake the posts. It will rebuild the post_uploadslinks”.
(Stephen Chung) #3
No it doesn’t.
Not if the entry in uploads no longer exists. Obviously post_uploads will not be created.
(Mittineague) #4
Is that a “no it doesn’t” I don’t think it will, or a “no it doesn’t” I did try that and it didn’t?
(Stephen Chung) #5
That is a “no it doesn’t because that was the first thing I tried.”
(Régis Hanol) #6
Yeah, if there’s no upload records then there won’t be any post_uploads.
How did you restore the uploads from the tombstone? Did you use the rake task?
(Stephen Chung) #7
Well… :sweat_smile: I just copied them…
Do you mean I can use a rake task to restore the uploads records also?
(Régis Hanol) #8
Yup, it’s called “uploads:recover_from_tombstone”.
(Stephen Chung) #9
This task only works for internal storages.
Sorry, I am using Azure Blob Storage.
(Régis Hanol) #11
My bad. In that case, you’d have to write some code to restore the uploads.
(Stephen Chung) #12
It should be a simple matter to strip out the copying step? I’m not sure how to do that…
(Stephen Chung) #13
So now the PR is merged to prevent missing uploaded file links, can some kind soul please help me write a ruby or psql script to rebuild the missing upload links?
