[Resolved] Recent change breaks connectivity in Docker (+ non-Docker)
I’ve had issues with being completely unable to connect to a Dockerised dev instance.
I thought I’d give the non_docker dev version a try. From there I could connect to localhost but not any other address. I then saw featheredtoast’s comment about changing the defaults in dev environments to ensure that they bind to localhost (64d51a). So on the Docker instance I checked out the rev prior to that, and I can connect to the Dockerised instance!
Steps to replicate:
  1. Follow Beginners Guide to Install Discourse for Development using Docker
  2. Connections to port 9292 (localhost, 127.0.0.1, ::1, or by IP) are immediately closed
  3. git checkout 4935c9f1f8db54312d8343a278c23cb0d3f6b61b (prior rev)
  4. Rebuild dev environment and run
  5. Connections to port 9292 work as expected
Sure, this is a great catch, addressed here:
https://github.com/discourse/discourse/commit/ff33899323f71ca750c0e555ce8f71d8896a3b3a
If you wish to globally expose the ports from the container to the network (default off) use.
d/boot_dev -p
Thanks @sam :+1:
Can confirm that with latest master (2 commits after yours at time of writing) connectivity seems to work as intended.
This topic was automatically closed after 29 hours. New replies are no longer allowed.
