Relationships between posts
(Refael Dakar) #1
Is there a way to connect between posts?
Some kind of a way to state which posts are related to others will be much appreciated.
(Rikki Tooley) #2
How do you mean? If you put a link to a post on the same forum in a reply, a link to that post appears in the right gutter.
And the post you link to gets a link in the gutter too:
(James Milligan) #3
You can paste links to other posts/topics and they will show up on the right of each post (the one you link to, and the one you link from).
(Refael Dakar) #4
Cool. Don’t know how I missed it. If it would have been in the post body with a special design that would have been better.
Thanks @haiku
(cpradio) #5
Like this?
Just place the link on its own line…
https://meta.discourse.org/t/should-views-column-be-removed/18941/2?u=haiku
