Latest stable release 2.8.13 fails to bootstrap. I’m wondering if there are any new requirements that should be met.
I, [2022-11-30T18:58:39.252132 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
ArgumentError: wrong number of arguments (given 3, expected 1)
[snip]
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 2073 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
I do not think the YAML changed since last update but I passed it through yamllint and removed all warnings (trailing whitespace and missing first space in comments), leaving long line errors aside since they never mattered.
Rebuild failed again with the same error: wrong number of arguments (given 3, expected 1)
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
- "templates/web.socketed.template.yml"
params:
db_shared_buffers: "256MB"
db_user: discourse
db_password: "REDACTED"
db_host: ''
# db_port: 5432
db_socket: /var/run/postgresql/.s.PGSQL.5432
# Each site has it own database
db_1_name: REDACTED
# db_work_mem: "40MB"
# version: tests-passed
version: stable
env:
# UNICORN_WORKERS: 3
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: 'REDACTED'
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'REDACTED'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: REDACTED
DISCOURSE_SMTP_PORT: 587
# DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
DISCOURSE_SMTP_USER_NAME: REDACTED
DISCOURSE_SMTP_PASSWORD: "REDACTED"
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
# LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## The CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
# DISCOURSE_CDN_URL: //discourse-cdn.example.com
## Saml plugin setting
DISCOURSE_SAML_TARGET_URL: REDACTED
DISCOURSE_SAML_CERT_FINGERPRINT: "REDACTED"
DISCOURSE_SAML_REQUEST_METHOD: post
DISCOURSE_SAML_FULL_SCREEN_LOGIN: true
DISCOURSE_SAML_CERT: "-----BEGIN CERTIFICATE-----
REDACTED
-----END CERTIFICATE-----"
DISCOURSE_SAML_NAME_IDENTIFIER_FORMAT: "urn:oasis:names:tc:SAML:2.0:nameid-format:persistent"
DISCOURSE_SAML_WANT_ASSERTIONS_SIGNED: false
DISCOURSE_SAML_DEFAULT_EMAILS_VALID: true
DISCOURSE_SAML_LOG_AUTH: true
DISCOURSE_SAML_SP_CERTIFICATE: "-----BEGIN CERTIFICATE-----
REDACTED
DISCOURSE_SAML_SP_PRIVATE_KEY: "-----BEGIN PRIVATE KEY-----
REDACTED
-----END PRIVATE KEY-----"
# DISCOURSE_SAML_AUTHN_REQUESTS_SIGNED: defaults to false
# DISCOURSE_SAML_VALIDATE_EMAIL_FIELDS: defaults to blank. This setting accepts pipe separated group names that are supplied in memberOf attribute in SAML payload. If the group name specified in the value matches that from memberOf attribute than the email_valid is set to
true, otherwise it defaults to false. This setting overrides DISCOURSE_SAML_DEFAULT_EMAILS_VALID.
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-assign.git
- git clone https://github.com/discourse/discourse-bbb.git
# - git clone https://github.com/discourse/discourse-calendar.git
- git clone https://github.com/discourse/discourse-chat-integration.git
- git clone https://github.com/discourse/discourse-checklist.git
- git clone https://github.com/discourse/discourse-encrypt.git
- git clone https://github.com/discourse/discourse-footnote.git
# - git clone https://github.com/discourse/discourse-github.git
- git clone https://github.com/discourse/discourse-policy.git
- git clone https://github.com/discourse/discourse-saml.git
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/discourse/discourse-spoiler-alert.git
# - git clone https://github.com/discourse/discourse-voting.git
- git clone https://github.com/discourse/discourse-whos-online.git
- git clone https://github.com/discourse/discourse-yearly-review.git
# - git clone https://github.com/angusmcleod/discourse-custom-wizard.git
# - git clone https://github.com/angusmcleod/discourse-events.git
# - git clone https://github.com/angusmcleod/discourse-locations.git
after_postgres:
- exec: sudo -u postgres createdb $db_1_name || true
- exec:
stdin: |
ALTER USER $db_user WITH PASSWORD '$db_password';
ALTER SCHEMA public OWNER TO $db_user;
cmd: sudo -u postgres psql $db_1_name
raise_on_fail: false
- exec:
stdin: |
GRANT ALL PRIVILEGES ON DATABASE $db_1_name TO $db_user;
ALTER DATABASE $db_1_name OWNER TO $db_user;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS pg_trgm;
UPDATE pg_database SET ENCODING = pg_char_to_encoding('UTF8') WHERE
datname = '$db_1_name' AND encoding = pg_char_to_encoding('SQL_ASCII');
run:
# - exec: rails r "SiteSetting.notification_email='info@unconfigured.discourse.org'"
This is simply a variable name for the database. It’s used in multisite environments. I do not think it has anything to do with the issue, since it did not change from earlier versions.
After commenting out all plugins and extra database, bootstrap succeeds.
After uncommenting extra database, it keeps bootstrapping.
I’m adding plugins by chunks so I can isolate the broken migration.
I found a failing case… Commenting out a chunk of suspicious plugins.
After a few attempts, I figured that the discourse-policy plugin is failing.
