Remove a site from a multisite instance
(eriko) #1
My search foo is failing me. I have set up our docker instance to support multisite and it is working well. Of the sites that we created for workgroups a couple have not caught on and I want to remove them. I can remove the entry from the multisite.yml config and delete the databases but I think that there may be more cruft remaining after I do this. Where else should I look for debris?
(Neil Lalonde) #2
You can also remove the uploads and backups directories for the site. In the docker container, they’ll be in /var/www/discourse/public/uploads/<sitename> and /var/www/discourse/public/backups/<sitename>.
