Remove speed display
(Stan Smith) #1
This is driving me nuts…
There is a speed display on the upper right-hand side on every page. Can this be removed?
(Jeff Atwood) #2
This only happens if you sign in as the admin user who installed the site.
Press alt and P to turn off the display, or log in as a different user.
(Stan Smith) #3
Thanks! I knew it had to be something simple.
(Sam Saffron) #4
Or, remove your self from the developer list and rebuild container.
  DISCOURSE_DEVELOPER_EMAILS: 'me@example.com'
(Felix Freiberger) #5
Alternatively, if you want to retain your developer permissions (being able to impersonate system) and want to disable the profiler completely, you can add
  DISCOURSE_LOAD_MINI_PROFILER: false
to the env:-block (source). Please indent the line with two spaces as shown here, or the devil himself will instantly consume your server per the YML specification.
