Remove timeline, full width boxes
(DB) #1
Hi, I’ve removed the timeline from my theme but the post and reply boxes in the material theme do not fill 100% width. How can I make them fill it?
(Joffrey Jaffeux) #2
Don’t have an instance at hand at the moment, would this work ?
.topic-body {
    width: 100%;
.timeline-container {
    display: none;
(DB) #3
Brilliant. Thanks! That worked perfectly.
(Joffrey Jaffeux) #4
thanks but I don’t think so, it will probably introduce layout issues.
(Jasper A Van Der Meer) #5
that’s gonna mess up more than it will fix I assume. @David_James_Ball did it work properly, also on mobile?
