Removing full name on all users
#1
Hi there, I’ve had some issues importing the full names from a mybb installation and I want to delete all the users full names so they can correct them later from their own preferences. I want to run the following command on the rails console:
User.all.each do |u|
    u.name = ""
    u.save
Is this the correct syntax?
(Régis Hanol) #2
While this would work, it will take a lot of time if you have a large number of users.
You should use this instead :wink:
User.update_all(name: "")
#3
Thank you! so just to be sure, it’s
without the
u.name = ""
u.save
right? Would this also work for changing email preferences? Like
 User.update_all(email_direct: false)
(Régis Hanol) #4
Launch the rails console and then just write
User.update_all(name: "", email_direct: false)
