Renaming Discourse's root directory?
(Franz) #1
For some reason (historical, undoubtedly), the root directory for my Discourse instance is /var/docker instead of the more logical /var/discourse.
Is it possible to do the renaming without too much hassle? What would the procedure be like?
(Jeff Atwood) #2
This is already covered in the #howto on upgrading to Discourse 1.0. Your install must have been quite old to predate 1.0…
(Franz) #3
Thanks Jeff, I had missed that.
Direct link:
The instructions worked flawlessly.
Yes, early adopter :slight_smile:
