Replication of specific categories over two instances
(German Viscuso) #1
Hi. Here’s my scenario. We’ll setup a discourse instance in the US and another one in China. The instances are different, not mirrored and localized to each region BUT we need to replicate a category called “knowledge base” from the US instance to the China instance (even if posts are in English). What can I do to get this done? Maybe replicate parts of the Postgres database between the instances? I believe all “knowledge base” posts will be by a single user.
Best! Thx for your advice
(Sam Saffron) #2
This is going to be a world of pain and require API usage … how brave are you feeling, do you have a developer to dedicate to this?
(German Viscuso) #3
Thx for answering. We have one Rails developer. How difficult is the code base? I saw that you guys don’t recommend it as a first Rails app :slight_smile:
#4
I would like to do something similar: replicate a category that already exists in our Discourse Forum into a new category on our forum. Is this now easier than [quote=“sam, post:2, topic:9234”]
a world of pain
[/quote]
(Sam Saffron) #5
  • When a topic is posted in category X on instance A - it must be “replicated” to instance B
  • When a topic is posted in category X on instance B - it must be “replicated” to instance A
  • Same goes for replies, if user A from site B replies to the topic you need to copy the reply over… and the user record over and so on.
  • And cross site likes, how do they work?
Bottom line, you are going to need a developer here to build it.
