"Reply-to" link in emails is showing https with a non-SSL port
(Jared Lerner) #1
Hi - I set Discourse to use https but in my email notifications it’s giving “respond” links with the http port (80):
Reply to: https://community.clarifai.com:80/
Where can I change that so that it puts 443 instead of the 80 http port?
Running this on Apache
Thanks.
(Rafael dos Santos Silva) #2
Is the site setting use_https turned on?
(Matt Palmer) #3
Do a search in your site settings and app.yml for mentions of your domain; my guess is you’ve snuck an explicit port in somewhere. It certainly isn’t usual behaviour for the URL generator to go sticking in ports where they’re not wanted.
(Jared Lerner) #4
Yep use_https is turned on
(Jared Lerner) #5
Nothing fishy in site_settings.yml. I don’t have an app.yml on my VM (at least I don’t think I do) - is there another common file I can look at?
(Matt Palmer) #6
Whatever .yml you’ve got in containers is where you need to look, as well as in the site settings UI. site_settings.yml is the list of settings, not what you’ve set them to; that’s kept in the database.
(Jared Lerner) #7
I don’t think I have a Containers folder. Is that Docker-specific?
Sorry to bug ya but this is driving me bonkers
(Felix Freiberger) #8
Yes, the container definition is Docker-specific.
Docker is the only installation method supported here.
