Replygif plugin and ssl/tls
(Lee_Ars) #1
Continuing the discussion from All right, I'm stupid - pups syntax?:
Yeah, just tried to run it, and it definitely no worky.
I don’t see a good way forward, either, unless replygif.net decides to support SSL/TLS.
(cpradio) #2
Yeah, the idea right now is setting up a reverse proxy, then in the admin > settings, pointing the replygif url to the reverse proxy. Not sure if that will work or not though (that is what I’m attempting to do at this point).
(cpradio) #3
Cool, the reverse proxy works!
README has been updated
