Replying to a deleted topic returns a cryptic message
(Sam Saffron) #1
One repro is (as admin)
  1. Go to PM
  2. In another window delete PM
  3. Reply to PM
You will get a weird 500 error as opposed to a message telling you the PM was deleted.
This may also be the case for standard topics
(Jeff Atwood) #2
@neil can you add this to your list, 500 is not good in this scenario.
(there is a related badness when you reply to a closed topic but it is not a 500)
(山) #3
Just happened to me. 500 server error in replying to a topic I didn’t know was deleted. This has happened before every time this scenario happens.
Only idea I can think of is to flash a warning when it is deleted and disable the reply button (which then prompts a user to decide to cancel the post).
(Johan Jatko) #4
Just happened to me as well.
Is it possible to maybe push an “topic moved/deleted” message in realtime to notify the user when he is writing?
(山) #5
Especially when he’s typing a manifesto and oops, all gone. Woe. :anger:
(Jeff Atwood) #6
This also happens for closed topics. It’s quite bad, @techapj you should add this to your list.
(James Kiesel) #7
I can grab this over the next couple days if it’s not imminently fixed.
(James Kiesel) #8
https://github.com/discourse/discourse/pull/3202
(Jeff Atwood) #9
Did we ever merge in this PR? I would like this addressed. Both for a closed topic and a deleted topic…
(Sam Saffron) #10
No, it needs a bit more work
(Jeff Atwood) #11
Perhaps you can help @techapj
(Arpit Jalan) #12
Fixed via
https://github.com/discourse/discourse/pull/3277
(Sam Saffron) #13
