Report "Total for period" shows wrong value
#1
Hi,
In the new report screens you can sort by end and start date. However, the “Total for period” is wrong.
See screenshot:
As you can see, I have only two posts today but the “Total for period” is 178.
(Edit: It’s the same for topics)
(Joffrey Jaffeux) #2
Indeed something is off, I’m currently fully reworking this part ATM anyways so it should be fixed soon.
#4
Alright. I’m currently working on a website which has to display my Discourse’s total posts for all time and daily. I was surprised to see such a huge number for “daily”.
Can I assume that “Total” will end up the correct number?
If so, I’ll comment the code where I call “Total” and only addition all the data until that fix.
(Joffrey Jaffeux) #5
Yes total should me more correct, at least it’s not computed the same way, so it shouldn’t be affected by the total for period bug.
(Joffrey Jaffeux) #6
I can’t reproduce this error on my instance so far, will try more tomorrow so I can be sure it’s not brought in next iteration.
#7
Installed version: v2.1.0.beta2 +2
My Discourse had data reimported from previous backups a few time. Otherwise, it’s pretty much vanilla.
#8
It’s also pretty strange that it displays 178. This number is out of nowhere. Could it count deleted messages or something?
This is my about.json
    "stats": {
        "topic_count": 122,
        "post_count": 354,
And this is my totals according to the reports
/admin/reports/posts Total for period 178
/admin/reports/topics Total for period 122
