Reset password not sending email
unsupported-install
(Deron Jensen) #1
Hello,
I have a PHPBB site that I run now, but Discourse looks much better. I setup a new Discourse site, but when I try to login as a new user, I try to “Reset my password”. But an e-mail is never sent. I am currently using SendGrid with an API key as my email system. The “Test Email” and “Invite Users” both work and sends e-mail. It does not appear to send the email at all. I watch port 2525 (the smtp for SendGrid) and nothing
Well, I am looking for any suggestions. Logs or anything that may prevent the email from being sent.
(Matt Palmer) #2
Hmm, that’s an interesting one. The places you want to go for logs are Admin -> Email -> Skipped and Admin -> Logs (and all subtabs, especially “Error Logs”). If there’s no indication of the e-mail in any of those, you’ve got a real stone whodunnit on your hands.
(Deron Jensen) #3
Thank Matt. I checked some of the logs, and there is not much interesting. I must say this Discourse is pretty nice. I did not use the Docker container for the install there was a Bitnami install on G Cloud. Maybe I will try the Docker version or try upgrading the version that was installed.
It shows me:
Version v1.7.4-dirty 1.8.0.beta9 Updates are available. Please upgrade!
Maybe that is worthwhile.
(Jay Pfaffman) #4
Aha. The Bitnami install was very old, last I knew, and not recommended.
Give the INSTALL-cloud a shot.
(Deron Jensen) #5
Thanks. Appreciate the help. The upgrade did not go so great. So I will the try the cloud install with Docker.
(Deron Jensen) #6
Yes. This is much better. Up and running in less than an hour.
