Restoration Failed while Migrating
#1
I am trying to migrate from DigitalOcean to Ovh. i have discourse installed already on Ovh. But, when i try to restore my backup, it displays - The restore failed. Please check the logs.
[    2016-09-23 13:01:33] 'rotimi' has started the restore!
    [2016-09-23 13:01:33] Marking restore as running...
    [2016-09-23 13:01:33] Making sure /var/www/discourse/tmp/restores/default/2016-09-23-130133 exists...
    [2016-09-23 13:01:33] Copying archive to tmp directory...
    [2016-09-23 13:01:33] Unzipping archive, this may take a while...
    [2016-09-23 13:01:33] EXCEPTION: Failed to unzip archive.
    gzip: /var/www/discourse/tmp/restores/default/2016-09-23-130133/jaratalk-2016-09-23-111225-v20160919054014.tar.gz: invalid compressed data--format violated
    [2016-09-23 13:01:33] /var/www/discourse/lib/backup_restore/utils.rb:10:in `execute_command'
    /var/www/discourse/lib/backup_restore/restorer.rb:178:in `block in unzip_archive'
    /usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `chdir'
    /usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `cd'
    /var/www/discourse/lib/backup_restore/restorer.rb:177:in `unzip_archive'
    /var/www/discourse/lib/backup_restore/restorer.rb:38:in `run'
    /var/www/discourse/lib/backup_restore/backup_restore.rb:164:in `block in start!'
    /var/www/discourse/lib/backup_restore/backup_restore.rb:161:in `fork'
    /var/www/discourse/lib/backup_restore/backup_restore.rb:161:in `start!'
    /var/www/discourse/lib/backup_restore/backup_restore.rb:20:in `restore!'
    /var/www/discourse/app/controllers/admin/backups_controller.rb:81:in `restore'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/base.rb:198:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rendering.rb:10:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:117:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:505:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:81:in `run_callbacks'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rescue.rb:29:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:164:in `block in instrument'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:164:in `instrument'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/base.rb:137:in `process'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.7.1/lib/action_view/rendering.rb:30:in `process'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal.rb:196:in `dispatch'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal.rb:237:in `block in action'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:43:in `serve'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/mapper.rb:49:in `serve'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:43:in `block in serve'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:30:in `each'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:30:in `serve'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:817:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:186:in `call!'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:164:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/builder.rb:63:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:38:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
    /var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/flash.rb:260:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/cookies.rb:560:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/query_cache.rb:36:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.5/lib/logster/middleware/reporter.rb:31:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/rack/logger.rb:38:in `call_app'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/rack/logger.rb:22:in `call'
    /var/www/discourse/config/initializers/100-quiet_logger.rb:13:in `call_with_quiet_assets'
    /var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/request_id.rb:21:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiler.rb:278:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/rack/middleware.rb:62:in `call'
    /var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/engine.rb:518:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/application.rb:165:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `public_send'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `method_missing'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:562:in `process_client'
    /var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:658:in `worker_loop'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:132:in `start'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/bin/unicorn:126:in `<top (required)>'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:23:in `load'
    /var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:23:in `<main>'
    [2016-09-23 13:01:33] Trying to rollback...
    [2016-09-23 13:01:33] There was no need to rollback
    [2016-09-23 13:01:33] Notifying 'rotimi' of the end of the restore...
    [2016-09-23 13:01:34] Cleaning stuff up...
    [2016-09-23 13:01:34] Removing tmp '/var/www/discourse/tmp/restores/default/2016-09-23-130133' directory...
    [2016-09-23 13:01:34] Unpausing sidekiq...
    [2016-09-23 13:01:34] Marking restore as finished...
    [2016-09-23 13:01:34] Finished!
i don’t understand what is happening. Please help
(Joshua Rosenfeld) #2
Looks to me that something is wrong with the backup file itself. Did you receive any errors when uploading the backup?
#3
There was no error when i was uploading the backup.
(Joshua Rosenfeld) #4
I’m not sure what to suggest beyond that - something is off with the backup.
#5
could it happening because the discourse on digitalocean is still up.
or should i upload the backup again?
(Joshua Rosenfeld) #6
No. Completely separate servers, not going to interact.
You could try, not going to hurt, but there could also be something else going on here - I’m not sure, sorry!
