Restore at adminjs is not working
(Erick Guan) #1
I have to restore a site backup which is about 650MB. After I clicked the Restore, nothing happened. There is no logs, neither in the site settings, nor the logs.
The backup is created by latest Discourse 0.9.9.14.
It’s forum.my-card.in. The backup filename is mycard-2014-07-28-154145 (1).tar.gz. There is 404 error for the restore url.
(Jens Maier) #2
Did you check the “allow restore” box in the site settings?
(Erick Guan) #3
If you don’t check that box, the Restore button would not be available.
(Erick Guan) #4
Tough migration from old installation.
I went to the rails console and control the importer manually.
And have to refresh the admin settings to see the settings edited weirdly.
(Marty ) #5
I encountered the same issue. I changed the settings to allow restore. Then restore button on the backup page became available (after a logout/login). After a click of the restore button for a backup, a confirm dialog is displayed. I hit confirm, and then nothing happens.
@fantasticfears It sounds like you have a work around. What is this ruby console thing?
Thanks!
(Marty ) #6
Here is trace in the log:
Started POST "/admin/backups/discourse-2014-08-05-132802-eastkb-data.tar.gz/restore" for 198.228.228.44 at 2014-08-05 14:51:32 +0000
ActionController::RoutingError (No route matches [POST] "/admin/backups/discourse-2014-08-05-132802-eastkb-data.tar.gz/restore"):
config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
config/initializers/silence_logger.rb:26:in `call'
lib/middleware/unicorn_oobgc.rb:95:in `process_client'
This is for a new install of version 0.9.9.15.
(Erick Guan) #7
Actually I init the BackupRestore and move the backup to the correct location. It’s unreproduce in the development environment.
Are you in middle of migration? Where is your backup file?
(Marty ) #8
I did a conversion of a phpBB locally and had planned to export locally and then import on my new production instance.
Via the admin console I did:
  • backup and download locally, and then
  • uploaded and attempted to restore.
After that didn’t work I gave up on the restore and did the conversion in production.
(Sam Saffron) #9
@zogstrip this is odd
                 restore_admin_backup POST     /admin/backups/:id/restore(.:format)                  admin/backups#restore {:id=>/[a-zA-Z0-9\-_]*\d{4}(-\d{2}){2}-\d{6}\.tar\.gz/i}
these constraints are a bit crazy. stuff should be POSTed to /admin/backups/restore and passed in via params or id should simply an int or a hash of the name.
If people want to call their backup frogs.tar.gz or whatever they should be allowed to.
(Sam Saffron) #10
@zogstrip the repro here is create a backup file with SPACE in the filename. It can not be restored.
Your call if you want to fix or close this, I am happy with either, this almost never comes up.
(Régis Hanol) #11
Just pushed a fix. Backups only require the .tar.gz or .tgz extensions :cherries:
(Régis Hanol) #12
