Restore failed at 'Validating metadata'
(AstonJ) #1
With this message:
[2015-07-23 00:29:37] [STARTED]
[2015-07-23 00:29:37] 'AstonJ' has started the restore!
[2015-07-23 00:29:37] Marking restore as running...
[2015-07-23 00:29:37] Making sure /var/www/discourse/tmp/restores/default/2015-07-23-002937 exists...
[2015-07-23 00:29:37] Copying archive to tmp directory...
[2015-07-23 00:29:37] Unzipping archive...
[2015-07-23 00:29:37] Extracting metadata file...
[2015-07-23 00:29:37] Validating metadata...
[2015-07-23 00:29:37]   Current version: 20150713203955
[2015-07-23 00:29:37] EXCEPTION: undefined method `[]' for nil:NilClass
[2015-07-23 00:29:37] /var/www/discourse/lib/backup_restore/restorer.rb:176:in `validate_metadata'
/var/www/discourse/lib/backup_restore/restorer.rb:35:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:161:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:158:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:158:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:17:in `restore!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:74:in `restore'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/base.rb:189:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:552:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:502:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:86:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications.rb:159:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications.rb:159:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.1.10/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.6/lib/mini_profiler/profiling_methods.rb:106:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal.rb:232:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:82:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:82:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/mapper.rb:45:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:73:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:59:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:692:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/conditionalget.rb:35:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/head.rb:11:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:124:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/flash.rb:254:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.0.16/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/cookies.rb:562:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/connection_pool.rb:621:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:82:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/remote_ip.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-0.8.3/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/methodoverride.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/runtime.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/sendfile.rb:112:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.6/lib/mini_profiler/profiler.rb:279:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/engine.rb:514:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/application.rb:144:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/builder.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:65:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:576:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:670:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:525:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
[2015-07-23 00:29:37] Trying to rollback...
[2015-07-23 00:29:37] There was no need to rollback
[2015-07-23 00:29:37] Notifying 'AstonJ' of the end of the restore...
Any ideas what going on here?
I’ve still got access to shared/standalone/backups/default on the old server if I need to use one of those backups instead…
(AstonJ) #2
Hmm I think I know what happened.
When you download the backup safari ungzips it - so the file ends in .tar - if you just add .gz to the end of the file you get the error above.
Using the backup that was stored on the server seems to have worked, however while restoring it did appear to ‘hang’, however going to the site in another tab and it was fine with the message from the system saying all was successfully restored …I wonder if it hanged because the new admin account I signed up on the fresh install had a different password? (I had to log in again in the new tab.)
Exception during restore: EXCEPTION: undefined method `[]' for nil:NilClass
(Régis Hanol) #3
The hanging is due to the fact that we’re losing the Message Bus session and can’t push message to the browser anymore. It’s usually fine the hit refresh after a couple of minutes.
(Jeff Atwood) #4
I thought we had a special console message telling people that, at that point in the restore? e.g. “complete, now wait and reload the site”?
(Régis Hanol) #5
It’s right after the bunch of CREATE INDEX lines. Sometimes, the restore is so fast, the message doesn’t have the time to be pushed to the client…
(Jeff Atwood) #6
Can we forcefully flush somehow?
(AstonJ) #7
While we’re talking about restoring - is it possible you guys can look into adding the ability to do it via the command line too?
On a busy forum, people will see an empty discourse install (with the prompt to sign up with the admin email) then have to wait for the admin to pick up new dns and do the restore (which could take a while on a very large forum).
The way I usually restore is copy everything over to the new server, create the db backup, then as soon as I have done that post an announcement saying we are moving to a new server (so any new posts made won’t be carried over), restore db on new server and change nameservers for the domain.
This means most people won’t even realise the site had moved servers - would be great to have something as seamless as this for Discourse.
(Régis Hanol) #8
You’re welcome :wink:
(AstonJ) #9
Totally out of my depth when it comes to CLI tools Régis :blush:
(Kane York) #10
It’s:
./launcher enter app
cd /var/www/discourse
script/discourse backup
ls public/backups/default
script/discourse restore my-forum-2015-07-20-031112
(AstonJ) #11
Thanks Kane, but what about the bit that says admin has to set allow_restore to true first? Will that be ignored?
(Kane York) #12
rails run SiteSetting.allow_restore = true
(Régis Hanol) #13
@sam is that something we can easily do with MessageBus?
(Sam Saffron) #14
We can do the standard thing many driver upgrades do … a client initiated redirect N seconds after it stops hearing from message bus or something
(Jared Needell) #15
Not sure if this is related but I setup a new discourse server, saved the back up from the live discourse server including files.
Went to do a restore on the new discourse server, it went through everything pretty fast and it’s just sitting at CREATE INDEX for about 15- 20minutes now. The back up file is 1.8 MB.
(Régis Hanol) #16
This happens when sidekiq is running while doing the restore. Will see if I can make sure it’s not running (instead of only being “paused”)
(Vikas) #17
This did not work for me. I had to run below command
discourse restore <my_backup>.tar.gz
