Restore Failed with Unexpected EOF in archive
(Ильинский) #1
I have very important data into backup from earlier version of Discourse (maybe 1.6). 400mb…
Need help!
Logs
[2017-04-19 22:46:56] Making sure /var/www/discourse/tmp/restores/default/2017-04-19-224656 exists...
[2017-04-19 22:46:56] Copying archive to tmp directory...
[2017-04-19 22:46:58] Unzipping archive, this may take a while...
[2017-04-19 22:47:04] Extracting metadata file...
[2017-04-19 22:47:04] Validating metadata...
[2017-04-19 22:47:04]   Current version: 20170419193714
[2017-04-19 22:47:04]   Restored version: 20170215151505
[2017-04-19 22:47:04] Extracting dump file...
[2017-04-19 22:47:05] EXCEPTION: Failed to extract dump file.
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
[2017-04-19 22:47:05] /var/www/discourse/lib/discourse.rb:26:in `execute_command'
/var/www/discourse/lib/backup_restore/restorer.rb:234:in `block in extract_dump'
/usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `chdir'
/usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `cd'
/var/www/discourse/lib/backup_restore/restorer.rb:233:in `extract_dump'
/var/www/discourse/lib/backup_restore/restorer.rb:41:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:163:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:19:in `restore!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:101:in `restore'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.8/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.8/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/mapper.rb:49:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.8/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiler.rb:278:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/rack/middleware.rb:62:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:562:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:658:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:132:in `start'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `<main>'
[2017-04-19 22:47:05] Trying to rollback...
[2017-04-19 22:47:05] There was no need to rollback
[2017-04-19 22:47:05] Notifying 'sashailinsky' of the end of the restore...
[2017-04-19 22:47:09] Cleaning stuff up...
[2017-04-19 22:47:09] Removing tmp '/var/www/discourse/tmp/restores/default/2017-04-19-224656' directory...
[2017-04-19 22:47:10] Unpausing sidekiq...
[2017-04-19 22:47:10] Marking restore as finished...
[2017-04-19 22:47:10] Finished!
Filename: -2017-02-20-175813-v20170215151505.tar.gz
(Rafael dos Santos Silva) #2
Is this file valid? When you upload the backup the size of it on Discourse UI is the same that you have locally?
(Matt Palmer) #3
That backup file is corrupt. If you have another backup, try that. Otherwise, it may be possible to extract the subset of information that is in the backup and create a new, valid backup file that will complete restoration. That will take some expertise in the arcane world of tar file formats to do, though. I know @pfaffman has been deep in that world recently, and he’s available for consulting.
(Ильинский) #4
Solved!
Fixed by 7zip and gzip :slight_smile:
