Returning uncatchable promises
(Sam Saffron) #1
Internally we follow a pattern similar to this quite extensively in our models:
 toggleBookmark() {
    const self = this, firstPost = this.get("postStream.posts")[0];
    var path = self.get('bookmarked') ? '/remove_bookmarks' : '/bookmark';
    this.toggleProperty('bookmarked');
    if (this.get("postStream.firstPostPresent")) { firstPost.toggleProperty("bookmarked"); }
    return Discourse.ajax('/t/' + this.get('id') + path, {
      type: 'PUT',
    }).catch(function(error) {
      self.toggleProperty('bookmarked');
      if (self.get("postStream.firstPostPresent")) { firstPost.toggleProperty('bookmarked'); }
      let showGenericError = true;
      if (error && error.responseText) {
        try {
          bootbox.alert($.parseJSON(error.responseText).errors);
          showGenericError = false;
        } catch(e){}
      if(showGenericError){
        bootbox.alert(I18n.t('generic_error'));
This raises a few red flags on my side which I would like to have a plan to address
Uncatchable promises
Consumers calling
post.toggleBookmark().catch(function(){
   // rollback UI
Are in for a rude surprise when they discover the catch code never fires.
UI is being triggered from models
The model has a dependecy on bootbox, which seems odd, view logic is creeping in to models.
How should we address these issues?
cc @eviltrout @zogstrip
On the “uncatchable promise thing”
Should we be throwing from inside the “catch” so stuff leaks out?
It just feels like we are setting us up with a models that do not allow the UI to respond to failure cleanly at the point of failure.
(Sam Saffron) #2
Had a quick chat with @wycats and the first recommendation here is to simply be rethrowing:
So:
return Discourse.ajax('/something').catch(function(error){
   // internal cleanup
   throw error;
This gives a chance to consumers to handle errors.
(Jacob Chapel) #3
I feel that UI code in a model is a recipe for trouble. That logic should live in a View, then that makes the call to the model’s method.
As far as uncatchable, while not a fan of promises, re-throwing seems to be one of the only options if you want to expose the error outside. If a consumer down the line doesn’t catch it, it will be ignored, so it should be safe as far as I can tell.
(Régis Hanol) #4
Yeah I agree that it’s not good. We should really only do the ajax request in the model and let the view handle the bootboxes.
(Kane York) #5
I actually have some code on my computer for a generic error modal view. It would take the jQuery XHR object, which is what the catch blocks get.
(Robin Ward) #6
The actual problem here, is what @zogstrip said that the model is doing too much. A refactor to make sure it’s only doing AJAXy/model stuff is the correct fix. The model should raise an error if something happens, the UI layer should do something about it.
If we want to “rethrow” as @wycats mentioned we can throw a new exception. Another alternative is to return a new broken promise. I made a source comment about this not that long ago.
